Live Signaling Capture with tbsigtrace
You activate tbsigtrace and pipe it directly in Wireshark through SSH to get a live capture of SS7, ISDN, SIP, Sigtran and H.248 (not all in the same wireshark window). This page provides the procedure for a Windows base operating system using plink and Wireshark tools.
WARNING: tbsigtrace application should not be used all the time, otherwise it might reduce performance. Also we suggest to do the live capture on only one Tmedia at a time.
The procedure is as following:
Download plink
Download 64 bit plink at https://the.earth.li/~sgtatham/putty/latest/w64/plink.exearrow-up-right Download 32 bit plink at https://the.earth.li/~sgtatham/putty/latest/w32/plink.exearrow-up-right Place it in C:\Program Files\Putty directory
Execute the command to capture the signalling accordingly
This is the structure of the command:
plink.exe -batch -ssh root@[IP_of_management_port] -P [ssh_port] -pw [ssh_password] "tbsigtrace -stdout -[protocol]" | "C:\Program Files\Wireshark\wireshark.exe" -k -i -
For SS7 capture
plink.exe -batch -ssh [email protected] -pw mypassword "tbsigtrace -stdout -ss7" | "C:\Program Files\Wireshark\wireshark.exe" -k -i -
For ISDN capture
plink.exe -batch -ssh [email protected] -pw mypassword "tbsigtrace -stdout -isdn" | "C:\Program Files\Wireshark\wireshark.exe" -k -i -
For SIP or SIGTRAN capture
plink.exe -batch -ssh [email protected] -pw mypassword "tbsigtrace -stdout -ip" | "C:\Program Files\Wireshark\wireshark.exe" -k -i -
For H.248 capture
plink.exe -batch -ssh [email protected] -pw mypassword "tbsigtrace -stdout -h248" | "C:\Program Files\Wireshark\wireshark.exe" -k -i -
For Radius or SNMP capture
Link to Signaling Trace Capture Tool page: tbsigtrace
