Script Parameters Definition for SIP
request_uri
Enables access to the Request-Line URI.
For example, if the Request-Line is:
Request-Line: INVITE sip:[email protected]:5060;user=phone;transport=udp SIP/2.0
Then the retrieved request_uri will be "sip:[email protected]:5060;user=phone;transport=udparrow-up-right SIP/2.0".
In the routing scripts, to retrieve only the called number, this script can be used:
    if call_params[:request_uri] && call_params[:request_uri] =~ /sip:(.*)@.*/
       call_params[:called] = $1
    end
request_uri_forward_enabled
This call parameter controls forwarding or discarding of request uri to outgoing call leg.The request uri is the information in the "Request-Line:" of the SIP INVITE message.
Values for this parameter are "0", "1", "false" or "true.
  • 0/false: Request uri is not forwarded to outgoing call leg
  • 1/true: Request uri is forwarded to outgoing call leg
The default value for this parameters is false.
sip_scheme
(Available in Toolpack 3.1+) This call parameter indicates the scheme (generally "sip" or "sips") of the incoming call.
This also allows the control of the scheme used for the outgoing call (regardless if request_uri_forward_enabled is used or not)
Note: sips scheme must only be used on TLS NAPs (will cause call routing failure if NAP has only UDP or TCP transport types).
When the call comes with sips scheme, they cannot be forwarded to sip UDP NAPs by default. Incoming calls with the “sips” scheme are only allowed to be routed to secure NAPS.
To enable this, you need to replace the following script part from the simple_routing_sbc.rb script:
Save the script and activate the configuration. This will allow you to process the sips scheme calls.
sip_header values
Contains custom sip headers from the inbound call leg. Any custom sip header can be added to an outgoing call leg:
Note:
The SIP header is in string format.
string format:
(Note: \n above are actual newline characters, not '\' followed by 'n')
  • PCAP sample
List of sip headers that will not appear in call[:sip_header] since they are already processed by the SIP stack:
Note: Since version 3.0.57, Referred-By is now a SIP custom parameter
sip header parameters
The routing script can read (and modify) some SIP header parameters (user parameters, URI parameters or header parameters) from some SIP headers (To, From, P-Asserted-Identity, Remote-Party-ID, Contact).
Available parameters
  • call[ :calling_parameters ] (SIP "From" header)
  • call[ :called_parameters ] (SIP "To" header)
  • call[ :private_address_parameters ] (SIP "P-Asserted-Identity" or "Remote-Party-ID" header)
  • call[ :supp_private_address_parameters ] (SIP supplementary/second "P-Asserted-Identity" header)
  • call[ :preferred_id_parameters ] (SIP "P-Preferred-Identity" header)
  • call[ :contact_parameters ] (SIP "Contact" header)
These parameters (if present) contain a hash with 3 keys: user_param, uri_param and header_param. Each of this key points to a string that contains all the parameters found in the corresponding SIP header.
Example to print all parameters of SIP "To" header:
Example to modify (replace) the URI parameters of SIP "To" header:
Exceptions
Note: Some parameters are reported as their own call attribute (oli, isub, cpc, transport) so they have the same representation for all protocols (SS7, IDSN, SIP). They will not appear in the generic SIP header parameters structures above.
Forwarding from inbound to outbound call
Legacy behavior
(For base_routing version 1.32 or older) By default, the parameters are not forwarded in a SIP to SIP call flow. The parameters will be forwarded when:
  • accessed (read) from either the inbound or outbound call parameters
  • written in either the inbound or outbound call parameters
Current behavior
(For Toolpack 3.0.118+, with base_routing version 1.33+) SIP headers host and parameters are forwarded by default.
A route attribute "forward_sip_domain" (along with filter script "forward_sip_domain.rb") will control, per route, if SIP headers host+parameters must be forwarded.
Example use
Example to print the user parameters:
Example SIP "From" header:
And the resulting content in the routing script:
Example to overwrite inbound leg calling parameters with new parameters for the outbound leg:
Example to add user=phone and keep all other uri parameters.
