To configure SIP settings, do the following:
1- Click SIP in the Editing Profile window, to display the customizable options.
2- Select one or more DTMF-Relay relay schemes. By default they are in this order:
You can change this by selecting Remove or << button to add them again
You can get more details here: DTMF-Relay 3- Modify Advanced settings as required.
Then click Save
SIP
Use SIP strict routing
Detect 180 with SDP as early media
Send 180 with SDP
Don't forward 183 progress
Use non ambiguous From tag
Use reason header
Use isup-oli format
Enable SIP Custom Headers
Forward SS7 suspend/resume
Forward SS7 CPG hold/retrieval
Forward SIP hold type
Max Forwards header handling
User-to-User encoding
SDP generation options
SDP combining options
Insert custom SIP BYE headers
Last updated 1 year ago
