Modifying Tone Definition Profile Settings
'Tone Definition Profiles' list the frequencies for each tone that is used in a telephone network. This can change from one country to the next, such as the sound of a ring or busy tone. You can create a customized tone definition profile by simply copying an existing one and then modifying it.
To create a tone definition profile:
1- Click Profiles in the navigation window.
2- Click the Tone Definition Profiles tab.
3- Copy a tone definition profile to use as a baseline for the new profile.
  • Click Copy
  • Provide a name for the new file.
  • Click Copy
4- Select the newly create profile from the User Profiles list.
5- Make changes to the profile.
  • Click Save
6-Return to the Profile page
  • Click Profiles in the navigation window.
7- Select the profile to which you wish to assign the new tone definition profile.
8- Click Tones and Call Progress Options
9- Select the newly created tone definition profile.
  • Click Save
chevron-rightNorthbound Interfacehashtag
Path
Parameters (text)
Parameters (json)
