LogoLogo
search
Ctrlk
Helpchevron-down
  • Overview
    • Introduction
    • Characteristics
    • Platforms
  • INITIAL Installation
    • 1. Instructions by platformchevron-right
    • 2. Initial Configurationchevron-right
    • 3. Uploading a Licensechevron-right
  • Use Cases
    • Applicationschevron-right
    • Interoperability Exampleschevron-right
  • CONFIGURATION DETAILS
    • Configuration By Web Portal Categorychevron-right
      • System Settingschevron-right
        • Setting the Role to Standalone
        • Setting the Role to a Primary Unit in a 1+1 System
        • Setting the Role to a Secondary Unit in a 1+1 System
        • Resetting the Host Role
        • Resetting the Network Device Role
        • Create Session Border Gateway Access Control List (ACL)
        • Session Border Gateway: Advanced Parameter Settngs
        • Create Session Border Gateway Access Control List (ACL) Filters
        • Connecting to the Web Server and Logging on to the Web Portal
        • Logging Off
        • Modifying Security Settings
        • Creating Web User groups
        • Creating Web Users
        • Modifying Web User Permissions
        • Enabling and Disabling a User
        • Deleting a User
        • Accessing Audit Logs
        • Activating the Configuration
        • Configuring a Web Portal Profile
        • Configuring the Date, Time, Timezone and NTP servers
        • Configuring the DNS
        • Create HTTP Service
        • Use HTTPS service
        • Configure HTTPS certificates
        • Configuring letsencrypt certificate
        • Configuring the ICMP
        • Configuring the SSH
        • Database Backup
        • Downloading a Database Backup
        • Uploading a Database Backup
        • Restoring a Database
        • Enabling the SNMP Agent
        • Configuring the SNMP Agent
        • Creating an SNMPv1/SNMPv2 Community
        • Creating an SNMPv3 User
        • Creating an SNMP Trap Destination
      • IP Network Settingschevron-right
      • SIPchevron-right
      • SIP Registrarchevron-right
      • Network Access Points (NAP)chevron-right
      • NAP Profileschevron-right
      • Call Routingchevron-right
      • Lawful Interceptchevron-right
      • Call Detail Records (CDR)chevron-right
      • Routing Scriptschevron-right
    • Configuration By Use Casechevron-right
    • Configuration Parameters (all)
    • Routing Script - SIP 302 Handling
  • Maintenance & Troubleshooting
    • Maintenance Guidechevron-right
    • Software version release notes
    • System Upgradechevron-right
    • ProSBC public roadmap
  • Troubleshooting & Support
    • Troubleshooting Tips & Actionschevron-right
    • Troubleshooting Common Problems
    • Support Linkschevron-right
    • How to use tbx cli tools remote program
  • Tools, Tips, and Tricks
    • TelcoBridges Magic Bookmark
    • Video Library
    • RESTful APIchevron-right
    • TBStatus APIchevron-right
  • Appendices
    • Appendix A: Glossarychevron-right
    • Appendix B: Product Datasheets
gitbookPowered by GitBook
block-quoteOn this pagechevron-down
  1. CONFIGURATION DETAILSchevron-right
  2. Configuration By Web Portal Categorychevron-right
  3. System Settings
The session border gateway feature is enabled by default. To verify or change the setting, do the following:
1-Click SBC in the navigation panel.
hashtag
Advanced Parameters
  • Connection debug mode
  • Default ban duration
  • List Sizes
    • Maximum accept entries
    • Maximum drop entries
    • Maximum filters
  • Default values for manual rules
    • Default entry duration
    • Default maximum bandwidth
    • Default temporary ban duration
  • Default values for OAMP rules
  • Default values for SIP rules
  • Default values for SIGTRAN rules
  • Default values for H.248 rules
PreviousCreate Session Border Gateway Access Control List (ACL)chevron-leftNextCreate Session Border Gateway Access Control List (ACL) Filterschevron-right
Last updated 7 months ago
