Network Access Points (NAP)
To create a new NAP
Associate a SIP transport server with the new NAP
Configure the access control list (optional)
Associate port ranges with the new NAP
Associate SIP Domains with the new NAP (optional)
Configure settings for the following parameter groups as required (optional)
Since 3.0.103 you have the option to disable a NAP. A disabled NAP will refuse incoming SIP calls, and will not be used for outgoing calls.
How to Create/Update a NAP with Restful API
PreviousCreating a SIP Register Filtering Rule ActionNextAllocating a SIP Open Network Access Point (NAP)
