Call Routing
Applies to ProSBC and Tmedia products
Add routes
Routing Script
TelcoBridges provides a large variety of routing script examples, which customers can apply directly in their web configuration by following just a few simple steps. Select one of the following examples according to your needs. You may modify it as needed.
Flexible NOA
Prefix NOA
Disable Route Retry
This section assumes:
The routing script is already implemented (you just need to add the label routing functionality)
The routeset definition and digimap files are already created
Update definition/digitmap files
RADIUS Authorization (with custom dictionary)
