LogoLogo
Ctrlk
Help
  • Overview
    • Introduction
    • Characteristics
    • Platforms
  • INITIAL Installation
    • 1. Instructions by platform
    • 2. Initial Configuration
    • 3. Uploading a License
  • Use Cases
    • Applications
    • Interoperability Examples
  • CONFIGURATION DETAILS
    • Configuration By Web Portal Category
      • System Settings
      • IP Network Settings
      • SIP
      • SIP Registrar
      • Network Access Points (NAP)
      • NAP Profiles
      • Call Routing
      • Lawful Intercept
      • Call Detail Records (CDR)
      • Routing Scripts
        • Development Guides & Tutorials
          • Accessing Routing Script Parameters
          • Parameter Mapping
          • Script Parameters Definition
          • Script Parameters Definition for SIP
          • Accessing Information about Registered Users
          • Route Parameters and Call Routing
          • Playing prompts, announcements, and tones
          • Recording
          • User-to-User Information
          • Radius Authorization
          • ENUM Query
          • DNS Query
          • Call Diversion Options
          • Call Transfer Requests
          • Redirection
          • Connect Number
          • Terminating Calls
          • NAP Status and other NAP Information
          • Telephony Services (CNAM Requests over SS7)
          • Custom User Context
          • Routing Script Tests
          • Create New Routing Script
          • Enable Routing Script
    • Configuration By Use Case
    • Configuration Parameters (all)
    • Routing Script - SIP 302 Handling
  • Maintenance & Troubleshooting
    • Maintenance Guide
    • Software version release notes
    • System Upgrade
    • ProSBC public roadmap
  • Troubleshooting & Support
    • Troubleshooting Tips & Actions
    • Troubleshooting Common Problems
    • Support Links
    • How to use tbx cli tools remote program
  • Tools, Tips, and Tricks
    • TelcoBridges Magic Bookmark
    • Video Library
    • RESTful API
    • TBStatus API
  • Appendices
    • Appendix A: Glossary
    • Appendix B: Product Datasheets
Powered by GitBook
On this page
  1. CONFIGURATION DETAILS
  2. Configuration By Web Portal Category
  3. Routing Scripts
  4. Development Guides & Tutorials
1- Click Gateway in the navigation panel.
2- Select the script you wish to use in Use script.
  • Click Save
  • Translate privacy information
  • Use alternate anonymous address
  • CDR System Id
  • Enable periodic CDR update
  • Periodic CDR update time
  • Reverse CDR call origin
  • CDR Mode
  • Use script
PreviousCreate New Routing ScriptNextConfiguration By Use Case
Last updated 6 months ago
