Call Diversion Options
It's possible to control the call flow when a call diversion information is received in the alerting state.
Two fields are available: bridge[ :diversion ] and bridge[ :diversion_reason ]
The internal release cause TOOLPACK_DIVERT_NOT_ALLOWED is used by gateway application to terminate both legs.
 bridge[ :diversion ] = :allowed
The alert message will not be analyzed and the call will be progressed. Default behavior.
 bridge[ :diversion ] = :not_allowed
If the alert message indicates that the call is diverted, the call will be released no matter the In-band information to allow early media.
 bridge[ :diversion ] = :not_allowed_w_early_media
The call will be released If the alert message indicates that the call is diverted with in-band information to allow early media.
 bridge[ :diversion_reason ] = "*"
If the diversion is not allowed, the gateway will drop the call for any redirecting reason.
 bridge[ :diversion_reason ] = "0,1,2"
or
 bridge[ :diversion_reason ] = "unknown,busy,no_reply"
If the diversion is not allowed, the redirecting reason will be analyzed and the call will only be dropped for the configured cases.
See Redirecting number reason valuesarrow-up-right.
