TelcoBridges uses a license-based approach to activate software or hardware functions in Toolpack or the underlying Telcobridges hardware. Whether you are installing Toolpack, implementing new software capabilities, or adding new hardware modules, you may be required to add or modify a license. The following instructions will enable you to do so.
IMPORTANT: You will need to reboot the telecom unit to activate the new license.
