Call Trace Filter Parameters
Filter parameter
When using the Call trace API to select a subset of calls, these are the parameter that can be used in the query.
Parameter
Format
Description
uct_call_id
Hexadecimal
Will return the call matching this ID.
direction
Integer
Incoming (1), outgoing (2), Mixer(3), Media only (4) .
max
Integer
Max number of call that will be matched by the filter.
called
String
Called number. Will match partial substrings of phone numbers.
calling
String
Calling number. Will match partial substrings of phone numbers.
nap
String
Nap used by the call.
protocol
String
Protocol used by the call (SS7, SIP, ISDN, CAS).
route
String
Name of the route used by the call.
call_id
String
SIP Call-Id header. Available for SIP call leg.
mos
String
MOS value from 1.0 to 5.0. Available for SIP call leg.
network_quality
Integer
Percentage from 1 to 100. Available for SIP call leg.
recorded
String
String can either be "RECORDED" or "NOTRECORDED".
call_state
String
"ACTIVE" or "INACTIVE"
terminate_reason
String or Integer
"NORMAL", "NOT_NORMAL" or the cause Integer value.
call_duration
Integer
All calls with a duration (in seconds) under the value of "call_duration". When the value prefixed by a '>', it will return all calls greater than the value.
A range can be obtained by inputing 2 values in the format 'x-y', where x is the minimum duration and y is the maximum.
intercepted
Boolean
True or false: Match all legs that are intercepted (if true) or all that are not (if false).
interception_leg
Boolean
Match all legs that are Interception legs
interception_liid
String
Match all legs that match the interception LIID
start
Integer or String
Unix timestamp (in milliseconds) for the beginning of the call. Match calls with a greater timestamp value. An external websitearrow-up-right can be used for converting the time into a timestamp. Can also use a string in the following format: 'YYYY-mm-dd HH:MM:SS'. Note that the timezone used will be the one on the queried system.
end
Integer or String
Unix timestamp (in milliseconds) for the end of the call. Match calls with a lesser timestamp value. An external websitearrow-up-right can be used for converting the time into a timestamp. Can also use a string in the following format: 'YYYY-mm-dd HH:MM:SS'. Note that the timezone used will be the one on the queried system.
drop_call
Boolean
Flag used to signify that all calls matching the filter parameters will be terminated. Use with caution when dropping multiple calls at once.
