Restoring a Database
The system configuration settings can be restored from a local or remote copy of a database.
Important Note: A database backup from a newer major version should NEVER be imported to an older major version.
If you have done this, please refer to:
** 1- Click Backups in the navigation panel
2- Initially the Recover feature is disabled. The database must first be validated before it can be restored.
Click Validate
3- After a few minutes, the web portal will return to an online status and if the backup validates successfully, the Recover link becomes active.
Click the Recover link to overwrite the current database and restore the backup file
Note: You must activate the configuration to apply the changes.
The database files backups are stored here:
/lib/tb/toolpack/pkg/database_backupsLast updated
