Import Customized Routing Script
1- Click Routing Script in the navigation panel
2- Select the desired script
3- Download the appropriate script according to your needs
file-archive
2KB
Note: Unzip the file so that it gives you the file Flexible_NOA.rb
4- Click Import Script File
5- Browse the ruby script file, for example "Flexible_NOA.rb"
  • ScriptType: Customer
  • Load on startup: checked
  • Click Import
