Call Detail Records (CDR)
To enable CDR:
1- Select Gateway from the navigation panel.
2- To enable CDR, select Use CDR behavior.
3- Configure the CDR behavior in the CDR Options section:
Enable periodic CDR update will add one entry in the CDR per Periodic CDR update time, in minutes.
Select one of the Text CDR mode from the CDR Mode :
Text CDR only: Will store the CDRs in a flat file.
RADIUS CDR only: Will send the CDR to an external RADIUS Server.
Text and RADIUS CDR: Will store the CDRs in a flat file and send the CDR to an external RADIUS Server.
RADIUS CDR with Text CDR Fallback: Will send the CDR to an external RADIUS Server and if the RADIUS server cannot handle the load of CDRs, they will be stored in a flat file.
Click Save to save your changes.
3- Expand the Text CDR parameters section
Configure the Text CDR parameters as required. Refer to the description of parameters described below.
