Call statistics available in CDR
Statistics
@{StatSummary}
Summary of the RTP and T.38 stats in a pre-defined format: RTP( Rx(Pkt=2 CN=0 Signaling=0 Err=0) Tx(Pkt=0 CN=0 Signaling=0 Err=0)) T38( Rx(Pages=0 Pkt=0 Err=0) Tx(Pages=0 Pkt=0)) MOS(In=4.3 Out=4.3}) NetworkQuality(In=100 Out=100) For customized format, use other variables below.
MOS statistics
@{Stat:MOS}
Summary of the MOS stats: (Codec;Ingress;Egress)
@{Stat:MOS:Codec}
Maximal MOS value for the audio codec used
@{Stat:MOS:Ingress}
Calculated MOS value using RTP RX statistics
@{Stat:MOS:Egress}
Calculated MOS value using RTCP statistics (available only when RTCP is enable)
@{Stat:MOS:Global}
Minimum value between MOS ingress and MOS egress
Network quality statistics
@{Stat:NetworkQuality}
Summary of the network quality stats: (Ingress;Egress)
@{Stat:NetworkQuality:Ingress}
Calculated network quality percentage from 0 (bad) to 100 (perfect) for packets received
@{Stat:NetworkQuality:Egress}
Calculated network quality percentage from 0 (bad) to 100 (perfect) for packets transmitted (available only when RTCP is enable)
@{Stat:NetworkQuality:Global}
Minimum value between ingress and egress
Receive statistics
@{Stat:Rtp:Rx}
Summary of the Rx stats: (Packets;CNPackets;SignalingPackets;Errors;MOS:Ingress)
@{Stat:Rtp:Rx:Packets}
Number of packets received from the IP network (audio + comfort noise + signaling)
@{Stat:Rtp:Rx:VoicePackets}
Number of voice (audio) packets received from the IP network
@{Stat:Rtp:Rx:VoiceBytes}
Number of payload bytes from voice (audio) packets received from the IP network
@{Stat:Rtp:Rx:CNPackets}
Number of comfort noise packets received from the IP network
@{Stat:Rtp:Rx:SignalingPackets}
Number of signaling packets (like "Telephony events") received from the IP network
@{Stat:Rtp:Rx:IPPackets}
@{Stat:Rtp:Rx:IPBytes}
Number of bytes received from the IP network
@{Stat:Rtp:Rx:RFC2833Tones}
Number of RFC2833 tones received from the IP network, and played back to TDM
@{Stat:Rtp:Rx:RedundantPackets}
Number of redundant packets received from the IP network (same sequence number received more than once)
@{Stat:Rtp:Rx:MeanPower}
Mean audio power (from IP to TDM direction), in dBov (0 the loudest, negative is softer level). Available only for calls with Echo cancellation enabled, thus only TDM<->IP calls.
@{Stat:Rtp:Rx:VoiceDuration}
Duration (in seconds) of voice (audio), from IP to TDM direction
@{Stat:Rtp:Rx:PlayoutDelay}
Current IP to TDM audio delay in millisecond (adaptive jitter buffer delay)
@{Stat:Rtp:Rx:MaxPlayoutDelay}
Maximum (for the whole call) IP to TDM audio delay in millisecond (adaptive jitter buffer delay)
@{Stat:Rtp:Rx:SsrcChanges}
Number of changes of "SSRC" RTP header value (counting initial SSRC received as one)
@{Stat:Rtp:Rx:Concealments}
Number of times decoder made audio concealment to preserve audio continuity (frequent upon first packet of a call, or after RFC2833 tones)
@{Stat:Rtp:Rx:Echo:ERLLevel}
Attenuation of a signal from the received-out port to the send-in port of an echo canceller
@{Stat:Rtp:Rx:Error:BufOverflows}
Number of packets dropped due to jitter buffer adaptation (to keep play-out delay low)
@{Stat:Rtp:Rx:Error:SeqErrors}
Number of sequence errors detected among packets received from the IP network
@{Stat:Rtp:Rx:Error:BadPackets}
Number of packets received with invalid header, or other error preventing proper audio decoding
@{Stat:Rtp:Rx:Error:RFC2833BadPackets:
Number of RFC2833 signaling packets that could not be properly decoded
@{Stat:Rtp:Rx:Error:LatePackets}
Number of packets that arrived after the moment they should have started to be played-out to TDM
@{Stat:Rtp:Rx:Error:LostPackets}
Number of packets considered "lost" (never received for play-out to TDM)
@{Stat:Rtp:Rx:Errors}
Total of all "Rtp:Rx:Error:" statistics above
Transmit statistics
@{Stat:Rtp:Tx}
Summary of the Tx stats: (Packets;CNPackets;SignalingPackets;Errors;MOS:Egress)
@{Stat:Rtp:Tx:Packets}
Number of packets sent to the IP network (audio + comfort noise + signaling)
@{Stat:Rtp:Tx:VoicePackets}
Number of voice (audio) packets sent to the IP network
@{Stat:Rtp:Tx:CNPackets}
Number of comfort noise packets sent to the IP network
@{Stat:Rtp:Tx:SignalingPackets}
Number of signaling packets (like "Telephony events") sent to the IP network
@{Stat:Rtp:Tx:IPPackets}
@{Stat:Rtp:Tx:IPBytes}
Number of bytes sent to the IP network
@{Stat:Rtp:Tx:RFC2833Tones}
Number of RFC2833 tones sent to the IP network (relaying corresponding detected TDM tones)
@{Stat:Rtp:Tx:MeanPower}
Mean audio power (from TDM to IP direction), in dBov (0 the loudest, negative is softer level). Available only for calls with Echo cancellation enabled, thus only TDM<->IP calls.
@{Stat:Rtp:Tx:VoiceDuration}
Duration (in seconds) of voice (audio), from TDM to IP direction
@{Stat:Rtp:Tx:Echo:ACOMLevel}
Attenuation of a signal from the receive-out port to the send-out port of an echo canceller
@{Stat:Rtp:Tx:Error:LostPackets}
Number of packets considered "lost" by remote side (only available if RTCP is used)
@{Stat:Rtp:Tx:Error:ArpFailure}
Number of failures to ARP remote IP address to send RTP packets to (preventing sending any packets)
@{Stat:Rtp:Tx:Errors}
Total of all "Rtp:Tx:Error:" statistics above
RTCP statistics
(only if RTCP is enabled on the profile)
@{Stat:Rtcp}
Summary of the Rtcp stats: (Packets;LostPackets;Jitter)
@{Stat:Rtcp:Packets}
Number of packets reported as received by remote equipment
@{Stat:Rtcp:LostPackets}
Number of packets reported as lost by remote equipment
@{Stat:Rtcp:Jitter}
Inter-packet interval jitter, in millisecond
@{Stat:Rtcp:RoundTripDelay}
Round-trip delay in milliseconds. Requires extended RTCP (XRTCP) to be enabled.
T38 statistics
@{Stat:T38:StateChanges}
Number of T.38 state changes, through T.30 negotiation between FAX machines
@{Stat:T38:Rx
Summary of the T.38 Rx stats: (Pages;Packets;Errors)
@{Stat:T38:Rx:Pages}
Number of FAX pages received from T.38 packets from the IP network
@{Stat:T38:Rx:Packets}
Number of T.38 packets received from the IP network
@{Stat:T38:Rx:Bytes}
Number of T.38 payload bytes from T.38 packets received from the IP network
@{Stat:T38:Rx:Duration}
Duration of the T.38 session from IP to TDM
@{Stat:T38:Rx:PlayoutDelay}
Current IP to TDM audio delay in millisecond (re-modulation and jitter buffer delay)
@{Stat:T38:Rx:MaxPlayoutDelay}
Maximum IP to TDM audio delay in millisecond (re-modulation and jitter buffer delay)
@{Stat:T38:Rx:Error:BufOverflows}
Number of packets dropped because "from IP" jitter buffer is full
@{Stat:T38:Rx:Error:BufUnderflows}
Number of times T.38 re-modulation to TDM had no data (received from IP) to re-modulate
@{Stat:T38:Rx:Error:SeqErrors}
@{Stat:T38:Rx:Error:BadPackets}
@{Stat:T38:Rx:Errors}
Total of all "T38:Rx:Error:" statistics above
@{Stat:T38:Tx}
Summary of the T.38 Tx stats: (Pages;Packets)
@{Stat:T38:Tx:Pages}
Number of FAX pages received from TDM, sent to T.38 packets to the IP network
@{Stat:T38:Tx:Packets}
Number of T.38 packets sent to the IP network
@{Stat:T38:Tx:Bytes}
Number of T.38 payload bytes from T.38 packets sent to the IP network
@{Stat:T38:Tx:Duration}
Duration of the T.38 session from TDM to IP
@{Stat:T38:FromTdm:MeanPower}
Mean audio power received from TDM side, in dBov (0 the loudest, negative is softer level)
Receive statistics
@{ErrorSummary}
Summary of reported leg errors in a pre-defined format: FromNetwork(NoPackets;ExcessivePackets;ExcessivePayloadTypeChanges;ExcessiveIpPortChanges;ExcessiveSsrcChanges) ToNetwork(NoPackets) For customized format, use other variables below.
@{Error:FromNetwork}
Summary of the leg errors 'from network': (NoPackets;ExcessivePackets;ExcessivePayloadTypeChanges;ExcessiveIpPortChanges;ExcessiveSsrcChanges)
@{FromNetwork:NoPackets}
When '1', no packets received from the network in the last few seconds, while packets were expected.
@{Error:FromNetwork:ExcessivePayloadTypeChanges}
When '1', excessive payload type changes were detected in the last few seconds. Payload type changes will be ignored. Packets may be dropped.
@{Error:FromNetwork:ExcessiveIpPortChanges}
When '1', excessive remote IP/Port changes were detected in the last few seconds. Received packets will be dropped.
@{Error:FromNetwork:ExcessiveSsrcChanges}
When '1', excessive remote SSRC changes (SSRC field in RTP packets header) were detected in the last few seconds. Received packets will be dropped.
@{Error:FromNetwork:ExcessivePackets}
When '1', excessive packets/bytes rate was received from the network. All packets will be dropped.
@{Error:ToNetwork}
Summary of the leg errors 'tonetwork': (NoPackets)
@{Error:ToNetwork:NoPackets}
When '1', no packets were sent to network in the last few seconds, while we were supposed to send packets (remote IP not reachable?)
