1- Click Routing Script in the navigation panel
2- Configure the new Routing Script:
Enter a name for the routing script
Make sure the box labeled Create default script files is checked
3- Verify that the Script was successfully updated message appears.
4- Disable simple routing:
Select Simple Routing.
5- Uncheck Load on startup
Click Save
Last updated 1 year ago
