NAP Status and other NAP Information
Routing script call attribute name Description
"name" NAP name.
"signaling_type" Signaling type (SS7, ISDN, CASR2, SIP)
"profile" Profile name.
"sip_destination_ip" Destination IP address.
"sip_destination_port" Destination IP port.
"sip_transport_type" SIP transport type (:udp, :tcp, or :tls) (Toolpack 3.1 and more)
"inst_incoming_call_cnt" Instantaneous Count of incoming calls.
"inst_outgoing_call_cnt" Instantaneous Count of outgoing calls.
"available_cnt" Number of available circuits or channels.
"unavailable_cnt" Number of unavailable circuits or channels.
"availability_percent" Percentage of available circuits or channels.
"usage_percent" Percentage of used circuits or channels.
"unused_shared_percent" Percentage of used circuits or channels of this NAP available to make new calls with (taking into account shared with other NAPs)
"total_incoming_call_cnt" Total Count of incoming calls.
"global_asr_percent" Global calculated ASR percentage.
"total_outgoing_call_cnt" Total Count of outgoing calls.
"last_24h_asr_percent" Last 24 hours calculated ASR percentage.
"last_24h_outgoing_call_cnt" Last 24 hours outgoing calls.
"current_hour_asr_percent" Current hour calculated ASR percentage.
"current_hour_outgoing_call_cnt" Current hour outgoing calls.
"last_hour_asr_percent" Last hour calculated ASR percentage.
"last_hour_outgoing_call_cnt" Last hour outgoing calls.
"poll_remote_proxy" Remote proxy polling enabled
"is_available" Remote proxy actually available or not
"time_since_polling" Time since the last availibility polling
"time_available_seconds" Number of seconds since the NAP is available
"time_unavailable_seconds" Number of seconds since the NAP is unavailable
"register_to_proxy" Register to proxy enabled
"registered" Actually registered or not
"time_since_refresh" Time since the last refresh
"time_registered_seconds" Number of seconds since the NAP is registered
"time_not_registered_seconds" Number of seconds since the NAP is not registered
"asr_stats_incoming_struct" Detailed Answer-Seizure Rate incoming statistics.
"total_call_cnt" Total count of calls.
"total_accepted_call_cnt" Total count of accepted calls (not dropped due to congestion or rate-limiting).
"total_answered_call_cnt" Total count of answered calls.
"last_24h_call_cnt" Last 24 hours count of calls.
"current_hour_call_cnt" Current hour count of calls.
"last_hour_call_cnt" Last hour count of calls.
"asr_stats_outgoing_struct" Detailed Answer-Seizure Rate outgoing statistics.
"mos_struct" Detailed Mean Opinion Score statistics.
"last_24h_ingress" Last 24 hours calculated MOS for incoming RTP packets.
"last_24h_egress" Last 24 hours calculated MOS for outgoing RTP packets.
"current_hour_ingress" Current hour calculated MOS for incoming RTP packets.
"current_hour_egress" Current hour calculated MOS for outgoing RTP packets.
"last_hour_ingress" Last hour calculated MOS for incoming RTP packets.
"last_hour_egress" Last hour calculated MOS for outgoing RTP packets.
"network_quality_struct" Detailed network quality statistics.
"last_24h_ingress" Last 24 hours network quality percentage for incoming RTP packets.
"last_24h_egress" Last 24 hours network quality percentage for outgoing RTP packets.
"current_hour_ingress" Current hour network quality percentage for incoming RTP packets.
"current_hour_egress" Current hour network quality percentage for outgoing RTP packets.
"last_hour_ingress" Last hour network quality percentage for incoming RTP packets.
"last_hour_egress" Last hour network quality percentage for outgoing RTP packets.
Example to access NAP information and NAP status of the current call
