Parameter Mapping
Script parameter name <>
ISDN <>
R2_CAS <>
SS7 <>
SIP <>
Comment
leg_id
N/A
N/A
N/A
N/A
Leg ID
session_id
N/A
N/A
N/A
N/A
Session ID
original_session_id
N/A
N/A
N/A
N/A
Original Session ID (before call transfer or redirections)
calling
Q931: 'Calling party number' IE - Number digits
ANI (Group B)
Q763: 'Calling party number' IE - address signals (*)
* In ANSI SS7 LNP networks, the IE 'generic address parameter' is used (when present) instead.
calling_sip_host
N/A
N/A
N/A
SIP:Fromarrow-up-right - host (domain or IP)
For example : The 'telcobridges.com' in From: "Cullen Jennings" <sip:[email protected]arrow-up-right>
calling_sip_port
N/A
N/A
N/A
For example : The '6060' in From: "Cullen Jennings" <sip:[email protected]:6060arrow-up-right>
calling_noa
Q931: 'Calling party number' IE - Type of number
N/A
Q763: 'Calling party number' IE - nature of address indicator (*)
N/A
calling_npi
Q931: 'Calling party number' IE - Numbering plan identification
N/A
Q763: 'Calling party number' IE - numbering plan indicator (*)
N/A
calling_display
Q931: 'Display' IE - Display information
Q931: 'Facility CNAM' IE when presentation is allowed for DMS/NI2 variants
N/A
Q763
ITU97: 'Display information' IE - display information ANSI95: 'Generic name' IE - display information
SIP:Fromarrow-up-right - display-name
calling_display_type
Q931: 'Display' IE - Display information (present and/or first byte)
N/A
Q763: 'Display information' IE - present or not
N/A
calling_presentation
Q931: 'Calling party number' IE - Presentation indicator
N/A
Q763: 'Calling party number' IE - address presentation restricted indicator
SIP:Fromarrow-up-right - display-name (displays 'anonymous' or not)
SIP:Remote-party-idarrow-up-right - privacy
calling_screening
Q931: 'Calling party number' IE - Screening indicator
N/A
Q763: 'Calling party number' IE - screening
calling_category
N/A
Call party category (Group A)
Q763: 'Calling party's category' IE - calling party's category
calling_subscriber
(Generic Number / NDS)
Q931: 2nd 'Calling party number' IE - Number digits
N/A
Q763: Generic number IE with type 'additional calling party number' - Number digits
Requires option 'support 2 calling number IE' in the profile. This variable has priority over 'private_address' in the outgoing direction.
calling_subscriber_noa
Q931: 2nd 'Calling party number' IE - Type of number
N/A
Q763: Generic number IE with type 'additional calling party number' - nature of address indicator
calling_subscriber_npi
Q931: 2nd 'Calling party number' IE - Numbering plan identification
N/A
Q763: Generic number IE with type 'additional calling party number' - numbering plan indicator
calling_subscriber_presentation
Q931: 2nd 'Calling party number' IE - Presentation indicator
N/A
Q763: Generic number IE with type 'additional calling party number' - presentation restricted indicator
calling_subscriber_screening
Q931: 2nd 'Calling party number' IE - Screening indicator
N/A
Q763: Generic number IE with type 'additional calling party number' - screening
private_display
Q931: 'Facility CNAM' IE when presentation is restricted for DMS/NI2 variants
N/A
N/A
private_display_type
N/A
N/A
N/A
N/A
Indicate presence or not of the private calling information
private_address
N/A
N/A
N/A
For example : The 'fluffy' in P-Asserted-Identity: "Cullen Jennings" <sip:[email protected]arrow-up-right>
private_address_sip_host
N/A
N/A
N/A
For example : The 'telcobridges.com' in P-Asserted-Identity: "Cullen Jennings" <sip:[email protected]arrow-up-right>
private_address_sip_port
N/A
N/A
N/A
For example : The '6060' in P-Asserted-Identity: "Cullen Jennings" <sip:[email protected]:6060arrow-up-right>
supp_private_address_forward_enabled
N/A
N/A
N/A
N/A
Overwrite default supplementary/second P-Asserted-Identity header forwarding behavior from incoming to outgoing leg
N/A
N/A
N/A
For example : The 'fluffy' in supplementary/second P-Asserted-Identity: "Cullen Jennings" <sip:[email protected]arrow-up-right>
supp_private_address_display_name
N/A
N/A
N/A
For example : The 'Cullen Jennings' in supplementary/second P-Asserted-Identity: "Cullen Jennings" <sip:[email protected]arrow-up-right>
supp_private_address_sip_host
N/A
N/A
N/A
For example : The 'telcobridges.com' in supplementary/second P-Asserted-Identity: "Cullen Jennings" <sip:[email protected]arrow-up-right>
supp_private_address_sip_port
N/A
N/A
N/A
For example : The '6060' in supplementary/second P-Asserted-Identity: "Cullen Jennings" <sip:[email protected]:6060arrow-up-right>
preferred_id_forward_enabled
N/A
N/A
N/A
N/A
Overwrite default P-Preferred-Identity header forwarding behavior from incoming to outgoing leg
preferred_id
N/A
N/A
N/A
For example : The 'fluffy' in P-Preferred-Identity: "Cullen Jennings" <sip:[email protected]arrow-up-right>
preferred_id_display_name
N/A
N/A
N/A
For example : The 'Cullen Jennings' in P-Preferred-Identity: "Cullen Jennings" <sip:[email protected]arrow-up-right>
preferred_id_sip_host
N/A
N/A
N/A
For example : The 'telcobridges.com' in P-Preferred-Identity: "Cullen Jennings" <sip:[email protected]arrow-up-right>
preferred_id_sip_port
N/A
N/A
N/A
For example : The '6060' in P-Preferred-Identity: "Cullen Jennings" <sip:[email protected]:6060arrow-up-right>
called
Q931: 'Called party number' IE - Number digits
DNIS (Group A)
Q763: 'Called party number' IE - address signals
SIP:Toarrow-up-right - user-info and host
called_sip_host
N/A
N/A
N/A
For example : The 'telcobridges.com' in To: "Cullen Jennings" <sip:[email protected]arrow-up-right>
called_sip_port
N/A
N/A
N/A
SIP:Toarrow-up-right - port number
For example : The '6060' in To: "Cullen Jennings" <sip:[email protected]:6060arrow-up-right>
called_noa
Q931: 'Called party number' IE - Type of number
N/A
Q763: 'Called party number' IE - nature of address indicator
N/A
called_npi
Q931: 'Called party number' IE - Numbering plan identification
N/A
Q763: 'Called party number' IE - numbering plan indicator
N/A
charge_number
N/A
N/A
ANSI: 'Charge number' IE - address signals
N/A
charge_number_noa
N/A
N/A
ANSI: 'Charge number' IE - nature of address indicator
N/A
charge_number_npi
N/A
N/A
ANSI: 'Charge number' IE - numbering plan indicator
N/A
redirecting_number_forward_enabled
N/A
N/A
N/A
N/A
Overwrite default redirecting number and original called number forwarding behavior from incoming to outgoing leg
redirecting_number
Q931: 'Redirecting number' 1st IE - Number digits
N/A
Q763: 'Redirecting number' IE - address signals
SIP:Diversionarrow-up-right (2nd header) - display-name
redirecting_number_noa
Q931: 'Redirecting number' 1st IE - Type of number
N/A
Q763: 'Redirecting number' IE - nature of address indicator
N/A
redirecting_number_npi
Q931: 'Redirecting number' 1st IE - Numbering plan identification
N/A
Q763: 'Redirecting number' IE - numbering plan indicator
N/A
redirecting_number_presentation
Q931: 'Redirecting number' 1st IE - Presentation indicator
N/A
Q763: 'Redirecting number' IE - address presentation restricted indicator
SIP:Diversionarrow-up-right (2nd header) - diversion-privacy
redirecting_number_indicator
N/A
N/A
Q763: 'Redirection information' IE - redirecting indicator
N/A
redirecting_number_reason
Q931: 'Redirecting number' 1st IE - Reason for redirection
N/A
Q763: 'Redirection information' IE - redirecting reason
SIP:Diversionarrow-up-right (2nd header) - diversion-reason
redirecting_number_counter
N/A
N/A
Q763: 'Redirection information' IE - redirection counter
SIP:Diversionarrow-up-right (2nd header) - diversion-counter
original_called_number
(OCN)
Q931: 'Redirecting number' 2nd IE - Number digits
N/A
Q763: 'Redirection number' IE - address signals
SIP:Diversionarrow-up-right (1st header) - display-name
original_called_number_noa
Q931: 'Redirecting number' 2nd IE - Type of number
N/A
Q763: 'Redirection number' IE - nature of address indicator
N/A
original_called_number_npi
Q931: 'Redirecting number' 2nd IE - Numbering plan identification
N/A
Q763: 'Redirection number' IE - numbering plan indicator
N/A
original_called_number_presentation
Q931: 'Redirecting number' 2nd IE - Presentation indicator
N/A
Q763: 'Redirection number' IE - address presentation restricted indicator
SIP:Diversionarrow-up-right (1st header) - diversion-privacy
original_called_number_reason
Q931: 'Redirecting number' 2nd IE - Reason for redirection
N/A
Q763: 'Redirection information' IE - original redirection reason
SIP:Diversionarrow-up-right (1st header) - diversion-reason
original_called_number_counter
N/A
N/A
N/A
SIP:Diversionarrow-up-right (1st header) - diversion-counter
ported_number_npdi
N/A
N/A
Q763: 'Generic number' IE - with qualifier=Ported number is present
SIP:RequestURIarrow-up-right - npdi=yes is present
Only valid if SIP/SS7 supports LNP
ported_number
N/A
N/A
Q763: 'Generic number' IE - address signals with qualifier=Ported number
SIP:RequestURIarrow-up-right - to user part when rn is present
rn is stored in the called number
ported_number_noa
N/A
N/A
Q763: 'Generic number' IE - nature of address indicator with qualifier=Ported number
N/A
ported_number_npi
N/A
N/A
Q763: 'Generic number' IE - numbering plan indicator with qualifier=Ported number
N/A
oli
(Originating line information)
5ESS Codeset 6 OLI - Value
N/A
ANSI: 'Originating line information' IE - OLI
request_uri
N/A
N/A
N/A
Complete Request URI string
request_uri_forward_enabled
N/A
N/A
N/A
N/A
Overwrite default URI forwarding behavior from incoming to outgoing leg
sip_header
N/A
N/A
N/A
Any header
Requires option 'Enable SIP Custom Headers' in Profiles->SIP
nap
(Network Access Point)
N/A
N/A
N/A
N/A
Incoming leg NAP name (read-only)
type_of_network_identification
Q931: 'Transit network selection' IE - Type of network identification
N/A
Q763: 'Transit network selection' IE - Type of network identification
N/A
Q931: 'Transit network selection' IE - Network identification
N/A
Q763: 'Transit network selection' IE - Network identification
SIP: Request-Line - cic
network_identification_plan
Q931: 'Transit network selection' IE - Network identification plan
N/A
Q763: 'Transit network selection' IE - Network identification plan
N/A
location_number_forward_enabled
N/A
N/A
N/A
N/A
Overwrite default location number forwarding behavior from incoming to outgoing leg
location_number
N/A
N/A
Q763: 'Location number' IE - address signals
N/A
location_number_noa
N/A
N/A
Q763: 'Location number' IE - nature of address indicator
N/A
location_number_npi
N/A
N/A
Q763: 'Location number' IE - numbering plan indicator
N/A
location_number_presentation
N/A
N/A
Q763: 'Location number' IE - presentation restricted indicator
N/A
location_number_screening
N/A
N/A
Q763: 'Location number' IE - screening
N/A
mlpp_forward_enabled
N/A
N/A
N/A
N/A
A script needs to set this to true if it wants to overwrite MLPP information in the outgoing leg. Otherwise, profile relay 'outgoing mode' applies automatically.
mlpp_look_for_busy
N/A
N/A
Q763: 'MLPP precedence' IE - look ahead for busy
N/A
mlpp_precedence_level
N/A
N/A
Q763: 'MLPP precedence' IE - precedence level
mlpp_network_identity
N/A
N/A
Q763: 'MLPP precedence' IE - network identity
N/A
mlpp_service_domain
N/A
N/A
Q763: 'MLPP precedence' IE - MLPP service domain
N/A
isub_forward_enabled
N/A
N/A
N/A
N/A
Overwrite default ISUB forwarding behavior from incoming to outgoing leg
called_isub
Q931: 'Called party subaddress' IE - subaddress information
N/A
Q763: 'Access transport' IE
SIP:Toarrow-up-right - isub parameter
called_isub_type
Q931: 'Called party subaddress' IE - type of subaddress
N/A
SIP:Toarrow-up-right - isub-encoding parameter
calling_isub
Q931: 'Calling party subaddress' IE - subaddress information
N/A
calling_isub_type
Q931: 'Calling party subaddress' IE - type of subaddress
N/A
SIP:Fromarrow-up-right - isub-encoding
ss7_fci_default
N/A
N/A
Default forward call indicator (FCI) value.
N/A
Toolpack will overwrite FCI bits A, D, F, I and M with appropriate values according to call conditions
ss7_fci_force_mask
N/A
N/A
Mask to select bits from ss7_fci_default that must be forced.
N/A
Bits from ss7_fci_default which corresponding bit in ss7_fci_force_mask is set will be forced, and no more controlled by Toolpack
ss7_bci_default
N/A
N/A
Default backward call indicator (BCI) value.
N/A
Toolpack will overwrite BCI bits A, B, I, K, M and N with appropriate values according to call conditions. These values are taken from ITU Q.763, section 3.5: Backward call indicators.
ss7_bci_force_mask
N/A
N/A
Mask to select bits from ss7_bci_default that must be forced.
N/A
Bits from ss7_bci_default which corresponding bit in ss7_bci_force_mask is set will be forced, and no more controlled by Toolpack
tdm_ls_name_forward_enabled
N/A
N/A
N/A
N/A
Enable line service and timeslot selection to create the outgoing leg. tdm_ls_name and tdm_timeslot_nb must be defined along with tdm_ls_name_forward_enabled
tdm_ls_name
(Line Service or T1/E1 trunk)
Incoming leg line service name
N/A
if tdm_ls_name_forward_enabled is set, try to use this line service name to create outgoing leg
tdm_timeslot_nb
Incoming leg timeslot number
N/A
if tdm_ls_name_forward_enabled is set, try to use this timeslot number to create outgoing leg
rtp_local_addr
N/A
N/A
N/A
Incoming leg local SDP IP address
(read-only)
rtp_local_port
N/A
N/A
N/A
Incoming leg local SDP IP port
(read-only)
rtp_remote_addr
N/A
N/A
N/A
Incoming leg remote SDP IP address
(read-only)
rtp_remote_port
N/A
N/A
N/A
Incoming leg remote SDP IP port
(read-only)
ss7_cot_enabled
N/A
N/A
Requests SS7 in-call continuity test for this outgoing SS7 call
N/A
Toolpack will request a continuity test on the timeslot before making the outgoing call. If COT fails, the call will be dropped (then another route may be attempted)
reverse_charging_indication
Incoming leg Reverse charging indication IE present
N/A
N/A
N/A
If set in routing script, will add Reverse charging indication IE in outgoing leg (also use reverse_charging_indication_forward_enabled)
N/A
N/A
N/A
N/A
Enable forwarding of reverse charging indication from incoming to outgoing leg
sip_call_id
N/A
N/A
N/A
Incoming leg SIP Call-Id
(read-only)
sip_local_addr
N/A
N/A
N/A
Incoming leg local SIP IP address
(read-only)
sip_local_port
N/A
N/A
N/A
Incoming leg local SIP port
(read-only)
sip_remote_addr
N/A
N/A
N/A
Incoming leg remote SIP IP address
(read-only)
sip_remote_port
N/A
N/A
N/A
Incoming leg remote SIP port
(read-only)
acli
N/A
N/A
'Additional Calling Party Information' IE - address signals.
A new ISUP parameter is defined under national option to carry the actual calling party number of the ported subscriber (N2) in the IAM message across the Network.
N/A
(read-only)
acli_nao
N/A
N/A
'Additional Calling Party Information' IE - nature of address indicator.
N/A
(read-only)
acli_npi
N/A
N/A
'Additional Calling Party Information' IE - numbering plan indicator.
N/A
(read-only)
acli_presentation
N/A
N/A
'Additional Calling Party Information' IE - address presentation restricted indicator.
N/A
(read-only)
acli_screening
N/A
N/A
'Additional Calling Party Information' IE - screening indicator.
N/A
(read-only)
