Radius Authorization
Beginning with release 2.7, you can issue RADIUS authorization requests from routing scripts. To do so, the params[:authorization] object must be filled with the required RADIUS attributes and an exception must be raised with reason :authorization_required.
When the authorization is completed, the routing script is called again with the result. The params[:authorization] object will be filled with the RADIUS attributes from the response. The params[:authorization][:result] field will also contain a string indicating the result of the authorization:
accept: The authorization was successful.
reject: The authorization was refused.
challenge: The authorization was challenged.
timeout: The authorization was not answered.
