Regular expression quick start guide
Quick Reference Table
Regular Expression Pattern
Explanations
Examples
Meta characters [\^$.|?*+(
Special caracters used in regex.
Must be escape with backslash "\" to use a literal characters.
Literal characters
All characters (except the metacharacters) match a single instance of themselves.
{ and } are literal characters, unless they're part of a valid regular expression token (e.g. the {n} quantifier).
/a/ matches "a"
[characters]
Character classes or character set. A character class matches a single character out of all the possibilities offered by the character class.
/[0-9]/ matches a single digit
[\d]
Shorthand character classes matching digits. Same as [0-9].
/[\d]/ matches a single digit
Dot matches any characters.
/a.c/ matches both "a4c" and "ayc"
Matches at the start of the string the regex pattern is applied to. Matches a position rather than a character.
Matches at the end of the string the regex pattern is applied to. Matches a position rather than a character.
{m,n}
Matches at least “m” and at most “n” occurrences of preceeding character, character class or group.
Matches zero or more occurrences of preceeding character, character class or group.
Matches one or more occurrences of preceeding character, character class or group.
Matches zero or one occurrences of preceeding character, character class or group.
Parentheses are used for group or capturing group
\0, \1, \2, ...
Substitute the value matched by the nth grouped sub-expression, used in remapped fields.
Not, as in "everything except this".
Examples
Here are some examples:
Add 2720 prefix:
or
Strip first 4 digits:
Strip # and 7 first digits:
Web Online Tools
Regular builder tool (with replace) : www.gskinner.com/RegExr
Tips to use:
No need to enclose the Regular expression with '/'.
Replace : the regular expression must be split in two parts and '\' replaced by '$'. For example, with '/^([0-9]*)$/2720\1/', the '^([0-9]*)$' would be filled on the first line and '2720$1' on the second line.
Ruby regular expression editor and tester : rubular.com
References
