LogoLogo
search
⌘Ctrlk
Helpchevron-down
LogoLogo
  • Overview
    • Introduction
    • Characteristics
    • Platforms
  • INITIAL Installation
    • 1. Instructions by platform
    • 2. Initial Configuration
    • 3. Uploading a License
  • Use Cases
    • Applications
    • Interoperability Examples
  • CONFIGURATION DETAILS
    • Configuration By Web Portal Category
    • Configuration By Use Case
    • Configuration Parameters (all)
    • Routing Script - SIP 302 Handling
  • Maintenance & Troubleshooting
    • Maintenance Guide
    • Software version release notes
    • System Upgrade
    • ProSBC public roadmap
  • Troubleshooting & Support
    • Troubleshooting Tips & Actions
      • Configuring Call Trace
      • Creating a test call
      • tbsigtrace: Signaling trace capture tool
      • How to Get Rid of Sub Optimal Warning
      • How to Lower The Trace Level on an Application
      • TBReport
      • VoIP Ethernet Capture on a ProSBC
      • Enabling Call Recording
      • Accessing the Call Recording
      • Routing Scripts
        • Update Your Routing Scripts
        • Disabling a Call Route
    • Troubleshooting Common Problems
    • Support Links
    • How to use tbx cli tools remote program
  • Tools, Tips, and Tricks
    • TelcoBridges Magic Bookmark
    • Video Library
    • RESTful API
    • TBStatus API
  • Appendices
    • Appendix A: Glossary
    • Appendix B: Product Datasheets
gitbookPowered by GitBook
block-quoteOn this pagechevron-down
  1. Troubleshooting & Supportchevron-right
  2. Troubleshooting Tips & Actions
Routing Scripts
Update Your Routing Scriptschevron-rightDisabling a Call Routechevron-right
PreviousAccessing the Call Recordingchevron-leftNextUpdate Your Routing Scriptschevron-right
