TMG:Change Management IP Address
TMG shell command
tbchangeipModify static IP address
Do you want to modify the network settings (enter 'help' for usage) ?[No] --> yes
Do you want to modify mgmt0 ?[No] --> yes
Select network mode (dhcp or static) ?[dhcp] --> static
Enter IP address ?[] --> 10.0.0.126
Enter network mask ?[] --> 255.255.255.0Last updated
