Host-control
Host control
Starting with Toolpack 2.5 a series of task are available to run from the host control panel (servers on which Toolpack is installed). The host control panel is accessed from the host status page. Its goal is to provide a common way to run Toolpack specific tasks, such as:
  • Upload a license
  • Upload a Toolpack package
  • Upgrade the host's packages (tblinux only)
  • Shutdown a host
  • Check control action status
Upload a license
Although it is still possible to manually copy the license to the appropriate folder on the host, this Upload action will take care of that task. It enables you to choose the license file to upload, and then install the license. Once this action is completed successfully, the OAM application loads the license and installs it on the appropriate TMedia unit. This will require a reboot of that unit.
This task uploads and installs the Toolpack installer on the specified host. You must still create a package and activate it so that the upgrade is applied at a suitable time. The only limitation is that this can only be used for minor upgrades, because the setup parameters will be lost for major upgrades.
Warning SELinux must be disabled (permissive or enforce SELinux will hinder package installation). Click here to disable SELinux.
This task updates all packages of the tblinux distribution to the latest stable version (assuming that the TMG has access to the web). This upgrade is recommended so that you always have the latest fixes. (This may take a while if the tblinux was not recently updated.)
Shutdown a host
This task will either reboot or shutdown a host depending on user input. This is especially important for the TMG, becauase it is important to shut it down properly to avoid corruption on the flash-based drive.
The status of each of the above actions can be viewed with two fields in the host control panel.
  • The current action log is the log of the action that is currently executing. This means only one action per host will be allowed at one time, however, you can queue them.
  • The last action log is the log of the last action that was completed (either successfully or with an error). The status can be refreshed buy pressing the 'now' button at the top of the page.
See this link for error codes description:
http://tldp.org/LDP/abs/html/exitcodes.htmlarrow-up-right
