Recovering an Elastic IP address
Recovering an Elastic IP address with AWS CLI
$ curl "https://awscli.amazonaws.com/awscli-exe-linux-x86_64.zip" -o "awscliv2.zip" unzip awscliv2.zip sudo ./aws/install aws --version
aws-cli/2.1.12 Python/3.7.3 Linux/3.10.0-1127.18.2.el7.tb.x86_64 exe/x86_64.centos.7 prompt/off AWS Access Key ID [None]: enter the Access Key Id from the credentials.csv file you downloaded in the Create an AWS IAM User part
Note: this should look something like AKIAPWINCOKAO3U4FWTN
AWS Secret Access Key [None]: enter the Secret Access Key from the credentials.csv file you downloaded in the Create an AWS IAM User part
Note: this should look something like 5dqQFBaGuPNf5z7NhFrgou4V5JJNaWPy1XFzBfX3
Default region name [None]: enter us-east-1
Default output format [None]: enter jsonRecovering an Elastic IP address with PowerShell
