Tmedia
3.0, 3.2, 3.3
SBC
3.1, 3.3
Note: This procedure does NOT affect the operation of your system.
New files are installed for the new release on the hard drive of the server in a separate folder from the current active release.
To upload a new release:
1- Log on to the web portal of your primary host, (if system has redundant hosts).
2- Click Packages & Licenses in the navigation menu.
3- Click Browse... and select the Toolpack installer (TBToolpack-...).
4- Once the file is selected, click Upload package.
This process will take a while, depending on the speed of the connection to the Web Portal.
Next step is to: Activate the new software
Last updated 1 year ago
