Uploading a License
TelcoBridges uses a license-based approach to activate various software or hardware functions in Toolpackarrow-up-right or the underlying hardware. When installing Toolpack, implementing new software capabilities, or after the addition of a hardware module, you may need to add or modify a license. The following instructions will enable you to do so.
Uploading licenses via the Web portal
  1. Click Packages & Licenses from the navigation panel.
  2. Click Browse and select the software license.
  3. Click Upload License.
  4. Wait for the page to reload and monitor the process by pressing the now button, from time to time.
  5. After a license update, click herearrow-up-right to see how to verify the license installation status.
IMPORTANT: If you have hardware units, you will need to restart it to apply the changes after installing a new license, unless it is for extending the end date, or making it permanent.
To do this, reboot the hardware unit (will drop active calls)
It will take about 1.5 minutes to restart the unit.
For more information see the host controlarrow-up-right page.
