Control Host Statistics
MaaS monitors the health and performance of your TMedia host servers and individual application processes. For 1+1 redundant deployments, each host is discovered and monitored separately with role identification.
Host Discovery
Hosts are automatically discovered from your TMedia configuration. The following information is captured:
Host Name
Configured hostname
Role
Primary or Secondary (for 1+1 systems)
Serial Number
Hardware serial number
Firewall Status
Whether TBRouter firewall is enabled
Host Status Metrics
Host State
Text
Operational state (Up/Down)
Reboot Required
Text
Whether a reboot is pending
Scheduling Problem
Count
Number of scheduling issues detected
License Expired
Text
License expiration status
License Expiring Soon
Text
License approaching expiration
Host Performance Metrics
CPU Usage
Overall CPU utilization
RAM Usage
Memory utilization
File System Used
Disk space utilization
File System Free
Available disk space (calculated)
Host Information
Firmware Version
Current software version
Serial Number
Hardware identification
Host Alerts
High Severity
Host Down
State ≠ "Up"
Host is not operational
File System 95%
Disk > 95%
Critical disk space
Warning Severity
File System 80%
Disk > 80%
Elevated disk usage
Application Statistics
MaaS discovers and monitors individual application processes running on each host.
Application Metrics
App State
Text
Application operational state
HA State
Text
High availability state
App CPU
Per-application CPU usage
Common Applications Monitored
Toolpack System Manager
toolpack_sys_mgr
Core system management
TBOAM App
tboam_app
OAM application
SNMP Agent
tbsnmpagent
SNMP interface
Stream Server
stream_server
Media streaming
TB Router
tbrouter
Firewall/routing (if enabled)
MySQL
mysqld
Database server
Ruby
ruby
Web interface
SNMP Daemon
snmpd
SNMP service
Sig Trace
tbsigtrace
Signaling trace
CLI Tools
tbx_cli_tools_remote
Remote CLI
IP Watchdog
ipwatchd
IP monitoring
KNI Single
kni_single
Kernel network interface
Application Alerts
High Severity
App CPU 95%
5-min avg > 94%
Critical CPU usage
Warning Severity
App CPU 80%
15-min avg > 79%
Elevated CPU usage
Understanding HA States
For 1+1 redundant deployments, application HA states indicate:
Active
Application is handling traffic
Standby
Application is ready for failover
Not Ready
Application is not in a ready state
Performance Troubleshooting
High RAM Usage
Memory issues may indicate:
Memory leaks (check application states)
Insufficient resources for call volume
Logging or caching issues
Disk Space Issues
Common causes of disk space consumption:
CDR/log accumulation
Core dumps
Signaling traces
Monitoring Best Practices
Baseline Your Environment
During normal operation, note typical values for:
Host CPU and RAM utilization
Disk space consumption rate
Set Appropriate Thresholds
Default thresholds (80%/95%) work for most deployments, but you may need to adjust based on your baseline if your system normally runs at higher utilization.
Monitor Both Hosts
In 1+1 deployments, don't ignore the standby host. Issues on standby will become problems during failover.
